Perform this procedure to display information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
 - Select Energy Saver.
 - Select the EEE Statistics tab.
 - Optional: Select Clear Stats to clear information about EEE statistics.
EEE Statistics Field Descriptions
The following table describes parameters on the EEE Statistics tab.
| Name | Description |
                                 Port  |
                                 Shows the port number.  |
                                 State  |
                                 Shows the state of Energy Efficient Ethernet (EEE) on the port.  |
                                 TxEvents  |
                                 Shows the EEE Tx event count for the port.  |
                                 TxDuration  |
                                 Shows the EEE Tx durations for the port.  |
                                 RxEvents  |
                                 Shows the EEE Rx event count for the port.  |
                                 RxDuration  |
                                 Shows the EEE Rx durations for the port.  |
