Use this procedure to configure LLDP and configure the status to transmit and receive on a port, or ports, on your switch.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. To configure LLDP and configure the status for transmit and receive on a port or ports, enter:
    lldp port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} status <txAndRx>
  3. To configure LLDP to the default setting for a port or ports, enter:
    default lldp port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} status <txAndRx>
Configure LLDP on your switch and set the status for transmit and receive on a port:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface GigabitEthernet 4/4
Switch:1(config-if)#lldp status txAndRx
Restore LLDP port status to the default value. The default status is disabled.
Switch:1>enable
Switch:1(config-if)#default lldp status
Disable LLDP on your switch:
Switch:1>enable
Switch:1(config-if)#no lldp status
The following table defines parameters for the lldp port command.
Variable
Value
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
status <txAndRx>
Configures the LLDP Data Unit (LLDP PDU) transmit and receive status on the port(s).
  • default—restores LLDP port parameters to default values
  • txAndrx—enables LLDP PDU transmit and receive
