Delete a multicast stream limitation member from an interface to remove it from the configuration.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
  1. In the navigation pane, expand the following folders: Configuration > IP.
  2. Click IGMP.
  3. Click the StreamLimit Members tab.
  4. Click on the row that lists the member you want to delete.
  5. Click Delete.
