Perform this procedure to view information about the operating status of the power supplies.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Power Supply.
  3. Select the Detail tab.
Detail Field Descriptions
Use the data in the following table to use the Detail tab.
Name
Description
Id
Specifies the ID number.
This field is not supported on all hardware platforms.
Type
Describes the type of power used.
Description
Provides a description of the power supply.
SerialNumber
Specifies the power supply serial number.
HardwareRevision
Specifies the hardware revision number.
PartNumber
Specifies the power supply part number.
PowerSupplyOperStatus
Specifies the status of the power supply as one of the following:
  • on (up)
  • off (down)
InputLineVoltage
Displays the input line voltage:
  • low 110v—power supply connected to a 110 Volt source
  • high 220v—power supply connected to a 220 Volt source
  • ac110vOr220v—power supply connected to a 110  Volt or 220 Volt source
OutputWatts
Displays the output power of this power supply.
InputOperLineVoltage
Displays the operating input line voltage.
If the power supplies in a chassis are not of identical input line voltage values, the operating line voltage shows the low 110v value.
InputPower
Displays the input power of this power supply.
FanFlowType
Note:
Exception: only supported on VSP 7200 Series
Displays the airflow direction of the power supply.
