Use the following command to configure the VRRP version on an interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
  2. Use the following command to configure the VRRP version:
    ip vrrp version <2–3>
  3. Use the following command to set the VRRP version to default:
    default ip vrrp version
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface gigabitethernet 1/2
Configure VRRP version for the specified interface:
Switch:1(config-if)# ip vrrp version 3
Variable definitions
Use the data in the following table to use the ip vrrp version command.
Variable
Value
version <2–3>
Configures the VRRP version (2 or 3) on the specified interface
