Force RIP to update the routing table so that the port or VLAN uses the latest routing information.
If you perform this procedure, you also update the tables for all VRFs associated with the port or VLAN.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
  2. Enable the triggered-update flag:
    ip rip triggered enable
    You can enable this flag in either the GigabitEthernet or VLAN Interface Configuration mode. However, you can update the RIP routes in the GigabitEthernet Interface Configuration mode only.
  3. Update the routing table:
    action triggerRipUpdate
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface vlan 1
Switch:1(config-if)#ip rip triggered enable
