Use this procedure to display BFD session information for IPv4 neighbors.
  1. To enter User EXEC mode, log on to the switch.
  2. Display BFD neighbor information:
    show ip bfd neighbors
  3. Optional: Display BFD neighbor next-hop information:
    show ip bfd neighbors next-hop {A.B.C.D}
  4. Optional: Display BFD neighbor information for a particular VRF:
    show ip bfd neighbors vrf WORD<1-16>
  5. Optional: Display BFD neighbor information for a VRF ID or a range of VRF IDs:
    show ip bfd neighbors vrfids WORD<0-512>
The following example displays BFD session information for an IPv4 neighbor.
Switch:1>show ip bfd neighbors
                                          BFD Session - GlobalRouter
MY_DISC    YOUR_DISC  NEXT_HOP        STATE      MULTI MIN_TX MIN_RX ACT_TX DETECT_TIME REMOTE_STATE APP    RUN
1          0          192.0.2.11      Down       3     200    200    1000   600         Down         O
  1 out of 1 BFD session displayed
APP and RUN Legend:
        B=BGP, O=OSPF, S=Static Route
The following table defines parameters for the show ip bfd neighbors command.
Variable
Value
{A.B.C.D}
Specifies the next-hop IP address in the format a.b.c.d.
vrf WORD<1-16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids WORD<0-512>
Specifies a range of VRFs by ID number (the ID ranges from 0–512).
