Use the following procedure to display the statistics of the number of packets mirrored into I-SID on the mirroring BEB.
    enable
    configure terminal
  2. Enter the following command:
    show isid-mirroring stats [monitor-isid-offset WORD<1-1024>]
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# show isid-mirroring stats monitor-isid-offset 1
			Mirror Statistics Info
ISID		ISID_OFFSET 	 PACKETS
16776000        1         	 100
The following table defines parameters for the show isid-mirroring stats command.
Variable
Value
monitor-isid-offset WORD<1–1024>
Specifies the offset ID mapped to monitor the I-SID.
The offset ID ranges from 1 to 1000.
