Make an SSH connection to a remote host.
Enable the SSH server on the remote host.
The command format, for the CLI SSH client command, is similar to Telnet with two additional parameters: -l login and an optional -p port parameter.
On IPv6 networks, the switch supports SSH server only. The switch does not support outbound SSH client over IPv6. On IPv4 networks, the switch supports both SSH server and SSH client.
  1. Enter Privileged EXEC mode:
    enable
  2. Connect to a remote host:
    ssh WORD<1–256> -l WORD<1–32> [-p <1–32768>]
Connect to the remote host:
Switch:1>enable
Switch:1#ssh 192.0.2.1 -l rwa
The following table defines parameters for the ssh command.
Variable
Value
WORD<1–32>
Specifies the user login name of the remote SSH server.
-p <1-32768>
Specifies the port number to connect to the remote SSH server. The default is 22.
