Show SLPP information for a port so that you can view the loop information for a port.
  1. Enter Privileged EXEC mode:
    enable
  2. View SLPP information for a port:
    show slpp interface GigabitEthernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
  3. Clear SLPP packet RX counters:
    clear slpp stats port [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Switch# show slpp interface GigabitEthernet 1/7
                                    Port Interface
   PORT        PKT-RX      PKT-RX     INCOMING   SLPP PDU
   NUM                     THRESHOLD  VLAN ID    ORIGINATOR
   1/7         enabled     5
   PORT        PKT-RX      TIME LEFT
   NUM         COUNT       TO CLEAR RX COUNT
   1/7         29          21600
Use the data in the following table to use the show slpp interface GigabitEthernet command.
Variable
Value
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
