View port spanning tree statistics to manage network performance.
  1. In the Device Physical View, select a port.
  2. In the navigation pane, expand the Configuration > Graph folders.
  3. Click Port.
  4. Click the Spanning Tree tab.
Spanning Tree Field Descriptions
The following table describes parameters on the Spanning Tree tab.
Name
Description
InConfigBpdus
The number of Config BPDUs received.
InTcnBpdus
The number of Topology Change Notifications BPDUs received.
InBadBpdus
The number of unknown or malformed BPDUs received.
OutConfigBpdus
The number of Config BPDUs transmitted.
OutTcnBpdus
The number of Topology Change Notifications BPDUs transmitted.
