Use this procedure to view the certificate configuration for the VM.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Display all configured entries:
    show running-config
  3. Display the CA trustpoint configuration:
    show certificate-config ca-trustpoint [<ca-label>]
  4. Display the subject-related configuration:
    show certificate-config subject [<subject-label>]
Switch:1>enable
Switch:1#virtual-service FIGW console
FIGW>show certificate-config ca-trustpoint
certificate {
    ca-trustpoint {
        ca-label a;
        caname subCaVpn;
        ca-url http://10.2.38.35:8080/ejbca/publicweb/apply/scep/test/pkiclient.exe;
        get-method post;
Switch:1>enable
FIGW>show certificate-config subject
certificate {
    subject {
        subject-label fig;
        DN CN=FIGW;
        key-label gigi;
    subject {
        subject-label figv;
        DN CN=figvpn;
