The procedure does not apply to VSP 8600 Series.
Use this task to enable IPv4 Fragmented ICMP packet filtering globally or on a specific VRF. This feature is disabled by default.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Enable Fragmented ICMP packet filtering:
    ip icmp drop-fragments
