Modify the egress mappings to change the mappings between the QoS levels and the IEEE 802.1p bits.
Do not change the default values. If you change the values, make sure that the values are consistent on all other devices in the network. Inconsistent mapping of table values can result in unpredictable service levels.
  1. In the navigation tree, expand the following folders: Configuration > QOS.
  2. Click Mapping Tables.
  3. Click the Egress QoS to 8021p tab.
  4. Double-click the Outleee8021P field to change the value.
  5. Click Apply.
Egress QoS to 8021p field descriptions
Use the data in the following table to use the Egress QoS to 8021p tab.
Name
Description
QosLevel
Specifies the QoS level of the outgoing packet.
Outleee8021P
Specifies the equivalent value of the IEEE 802.1p bit.
