Configure SLPP Guard on MLT and LAG ports to provide additional network loop protection.
SLPP Guard is disabled by default.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Enable SLPP Guard on the port:
    slpp-guard enable
  3. Optional: Configure the timeout value on the port:
    slpp-guard timeout {<10-65535> | 0}
Switch:1(config-if)#slpp-guard enable
Switch:1(config-if)#slpp-guard timeout 120
Variable definitions
Use the data in the following table to use the slpp-guard command.
Variable
Value
timeout <0 | 10–65535>
Specifies the time period, in seconds, for which SLPP Guard disables the port. After the timeout period expires, the switch reenables the port. The timeout value can be 0 or a value ranging from 10 to 65535. With a value of 0, the port remains disabled until it is manually re-enabled.
The default timeout value is 60 seconds.
