Configure the SA limit to limit the number of SA messages from an MSDP peer that the router saves in the SA cache. The default value is 6,144 messages.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Configure the SA limit:
    ip msdp sa-limit {A.B.C.D} <0-6144>
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp sa—limit 21.0.0.2 6100
Variable definitions
The following table defines parameters for the ip msdp sa-limit command.
Variable
Value
{A.B.C.D}
Specifies the MSDP peer IP address.
<0-6144>
Specifies the maximum number of SA messages to keep in SA cache.
