Use this procedure to configure the subject parameters to identify the device.
Switch:1>enable Switch:1#virtual-service FIGW console FIGW>set certificate subject ExtremeLab DN "CN=subca5, OU=Test, O=Extreme, L=Town, ST=State, E=email@extremenetworks.com" FIGW>set certificate subject ExtremeLab key-label key1
The following table defines parameters for the set certificate subject command.
                                 Variable  |
                                 Value  |
                                 DN <name>  |
                                 Specifies the distinguished name. You can create a comma-separated list.  |
                                 key-label <key-label>  |
                                 Specifies the key name of the generated key pair. This parameter is optional. If you do not configure one, the switch generates one the same as the subject-label.  |
                                 <subject-label>  |
                                 Specifies the subject identity. You cannot use the following special characters:
