Use the following procedure to bind a certificate identity to the IKE certificate store.
The following table defines parameters for the ike certificate-identity command.
Variable | Value |
cert-subject-name WORD<1-45> | Specifies the digital certificate subject name to be used as the identity certificate. If a subject name is not specified, the default subject name is Global. |
