Display OSPF authentication information to ensure accuracy.
View the OSPF authentication information:
Switch:1#show ip ospf int-auth ================================================================================ OSPF Interface AuthKey - GlobalRouter ================================================================================ INTERFACE AUTHTYPE AUTHKEY -------------------------------------------------------------------------------- 192.0.2.1 none 192.0.2.11 none 192.0.2.3 none
Variable definitions
The following table defines parameters for the show ip ospf int-auth command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
