This procedure does not apply to VSP 8600 Series.
Use this task to view UDP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 UDP tab.
IP/IPv6 UDP Field Descriptions
Use the data in the following table to use the IP/IPv6 UDP tab.
Name |
Description |
IPVersion |
Shows the IP address version as ipv4 or ipv6. |
InDatagrams |
Shows the input datagram statistics. |
NoPorts |
Shows the number of ports statistics. |
InErrors |
Shows the input errors statistics. |
OutDatagrams |
Shows the output datagram statistics. |
IgnoredMulti | Show the ignored multiport statistics. |
RcvbufErrors | Shows the received buffer errors statistics. |
SndbufErrors | Shows the send buffer errors statistics. |
InCsumErrors | Shows the input checksum errors statistics. |
Clear | Specifies to clear the statistics. Default is false. |
