Use the following procedure to clear all the forwarding database (FDB) for VLANs associated with this port.
  1. In the Device Physical View tab, select a port.
  2. In the navigation tree, expand the following folders: Configuration > Edit > Port.
  3. Click General.
  4. In the Interface tab Action box, select FlushMacFdb.
  5. Click Apply.
    All learned MAC addresses are cleared from the forwarding database (FDB) for VLANs associated with this port.
  6. Click Close.
