View the multicast group trace to track the data flow path of multicast streams.
  1. In the navigation pane, expand Configuration > IP.
  2. Click IGMP.
  3. Click the Snoop Trace tab.
Snoop Trace Field Descriptions
Use the data in the following table to use the Snoop Trace tab.
Name
Description
GrpAddr
Displays the IP multicast address of the group traversing the router.
SrcAddr
Displays the IP source address of the multicast group.
OutVlan
Displays the egress VLAN ID for the multicast group.
InPort
Displays the ingress port for the multicast group.
InVlan
Displays the ingress VLAN ID for the multicast group.
OutPort
Displays the egress port of the multicast group.
Type
Displays the port type on which the snoop entry is learned.
