View MLT statistics to display MultiLinkTrunking statistics for the switch or for the specified MLT ID.
  1. To enter User EXEC mode, log on to the switch.
  2. View MLT statistics:
    show mlt stats [<1-512>]
Switch:1#show mlt stats
                                 Mlt Interface
ID IN-OCTETS          OUT-OCTETS         IN-UNICST          OUT-UNICST
1  256676904          183670662          1397               456
2  61737348498        61584347982        1450182            1490619
4  229256124          47472778           0                  0
100 251678170          32332107           0                  0
ID IN-MULTICST        OUT-MULTICST       IN-BROADCST        OUT-BROADCST      MT
1  2419514            2295274            41                 268194            E
2  962303832          960067410          765                237               E
4  2159884            666153             0                  90                E
100 2095269            504965             13                 0                 E
ID IN-LSM             OUT-LSM
1  0                  0
2  957925732          957929399
4  0                  0
--More-- (q = quit)
Use the data in the following table to help you use the show mlt stats command.
Variable
Value
<1-512>
Specifies the MLT ID.
