Configuring an ACE TCP flag
Configure ACE TCP flag entries to have the filter look for packets with a specific TCP flag.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Click Advanced Filters (ACE/ACLs).
  3. Click the ACL tab.
  4. Select the appropriate ACL.
  5. Click ACE.
  6. Select the appropriate ACE.
  7. Click Proto.
  8. Click the TCP Flags tab.
  9. Click Insert.
  10. Specify the operator for the TCP flags entry.
  11. In the List box, specify the TCP flags to match.
  12. Click Insert.
TCP Flags field descriptions
Use the data in the following table to use the TCP Flags tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
List
Specifies one or more TCP flags—none, fin (finish connection), syn (synchronize), rst (reset connection), push, ack (acknowledge), urg (urgent), and undefined.
OperMask
Specifies the mask value.
