Use the following procedure to create and configure an IKE Phase 1 policy.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click IKE.
  3. Click the Policy tab.
  4. Click Insert.
  5. In the LocalIfIndex field, click either Port or Vlan, and then select an interface.
  6. In the LocalAddrType field, select the type of the local address.
  7. In the LocalAddr field, type the address of the local peer.
  8. In the RemoteAddrType field, select the type of the remote address.
  9. In the RemoteAddr field, type the address of the remote peer.
  10. In the Name field, type the name for the policy.
    Name must be assigned when creating the policy. Once the policy is created, the name cannot be changed.
  11. Complete the remaining optional configuration to customize the policy.
  12. Click Insert.
Policy field descriptions
Use the data in the following table to use the Policy tab.
Name
Description
LocalIfIndex
Specifies the Interface Index of the local address. Only port and vlan interfaces are supported.
LocalAddrType
Specifies whether the local address is an IPv4 or IPv6 address.
LocalAddr
Specifies the address of the local peer.
RemoteAddrType
Specifies whether the remote address is an IPv4 or IPv6 address.
RemoteAddr
Specifies the address of the remote peer.
Name
Specifies the name given to the policy. The name should be assigned while creating the policy. You cannot change the name after the policy is created.
ProfileName
Specifies the name of the profile that should be used for this policy.
ProfileVersion
Specifies the profile version used for the policy.
PeerName
Specifies the peer name.
AuthenticationMethod
Specifies the proposed authentication method for the Phase 1 security association.
The default authentication method is pre-shared key.
PSKValue
Specifies the value of the Pre-Shared Key if the authentication method is set to PSK.
DPDTimeout
Specifies the Dead Peer Detection timeout in seconds.
Default value is 300 seconds.
P2PFS
Specifies whether or not the perfect forward secrecy (PFS) is used when refreshing keys. To use PFS, select enable.
The default value is disable.
P2PfsUseIkeGroup
Specifies whether or not to use the same GroupId (Diffie-Hellman Group) for phase 2 as was used in phase 1. Ignore this entry if P2PFS is disabled.
The default value is enable.
P2PfsDHGroup
Specifies the Diffie-Hellman group to use for phase 2 when P2PFS is enabled and P2PfsUseIkeGroup is disabled.
The default value is mod1024.
AdminState
Specifies whether the policy is administratively enabled or disabled.
OperStatus
Shows is the policy is operationally up or down.
RevocationCheckMethod
Specifies the revocation check method as OCSP, CRL or none.
