Configure an IPv6 IS-IS accept policy for a specific I-SID to represent local or remote Layer 3 VSNs, which allows the system to redistribute the remote VSNs to the VSN where you applied the filter.
![Note](images/note.png)
If the route policy changes, you must re-apply the IPv6 IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map.
Change the VRF instance as required to configure an IPv6 IS-IS accept policy for a particular I-SID on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
- Click IS-IS.
- Click the Accept Isid tab.
- Click Insert.
- In the Isid field, specify the I-SID value.
- Select Enable to apply the filter.
- Optional: In the PolicyName field, specify the route-map name.
- Click Insert.
Accept Isid Field Descriptions
Use the data in the following table to configure the Accept Isid tab.
Name |
Description |
Isid |
Specifies a particular I-SID number that represents local or remote Layer 3 VSNs to which the IPv6 IS-IS accept policy applies. An I-SID value of 0 represents the global routing table (GRT). |
Enable |
Enables or disables the I-SID entry. The default is disabled. |
PolicyName |
Specifies the route policy name. |
