View the Local SA Cache
View the local SA cache to display the (S, G) state the router learns from local Protocol Independent Multicast - Sparse Mode (PIM-SM) entries.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
- Select MSDP.
- Select the SA-Cache-Records tab.
SA-Cache-Records field descriptions
Use the data in the following table to use the SA-Cache-Records tab.
Name |
Description |
TypeInformation |
Shows the SA cache type. The SA cache type can be local or foreign cache. |
GroupAddr |
Shows the group IP address of the SA cache entry. |
SourceAddr |
Shows the source IP address of the SA cache entry. |
OriginRP |
Shows the RP address of the SA cache entry. |
OriginatorAsNumber |
Shows the AS number of the originator. |
RouteType |
Shows the type of route used for Reverse Path Forwarding checking. The value can be rip (1), ospf (2), static (3), bgp (4), isis(5) or none (6). |
