Use the ingress port-rate limiter to limit the traffic rate accepted by the specified ingress port. The system drops or re-marks violating traffic.
  1. In the Device Physical View tab, select a port.
  2. In the navigation pane, expand the Configuration > Edit > Port folders.
  3. Click General.
  4. Click the Interface tab.
  5. From IngressRateLimit , type the value in Kbps to set the traffic rate limit.
    The ingress rate limit must be between 1000 and 40000000.
  6. Click Apply.
