Use the following procedure to display the configured IKE Phase 1 for version 1 and 2 security associations (SA).
  1. Enter Privileged EXEC mode:
    enable
  2. Display all the security associations:
    show ike sa
  3. Display security associations for IKE Phase 1 for version 1:
    show ike sa version v1 WORD<1-32> laddr WORD<1-256> raddr WORD<1-256>
  4. Display security associations for IKE Phase 1 for version 2:
    show ike sa version v2 WORD<1-32> laddr WORD<1-256> raddr WORD<1-256>
Switch:1(config)#show ike sa version v1
                      IKE V1 Phase 1 Security Association
Policy          Addr                                                       Initiator/
Name           Type Local Address              Remote Address             Responder
ikepsk          IPv4 192.0.2.5                 198.51.100.15              Initiator
                DPD        Hash   Encrypt   DH     Lifetime
Name            Timeout    Algo   Algo     Group   seconds    Status
ikepsk          300        sha    aesCbc  modp2048 3600       active
Switch:1(config)#show ike sa version v2
                      IKE V2 Phase 1 Security Association
v2policy        IPv4 203.0.113.6               198.51.100.20              Responder
                DPD        Hash   Encrypt Integrity  DH         Lifetime
Name            Timeout    Algo   Algo    Algo        Group     seconds    Status
v2policy        300        sha256 aesCbc             modp2048   86400      active
Variable Definition
The following table defines parameters for the show ike sa command.
Variable
Value
sa
Specifies the IKE security association identifier.
Specifies the local IPv4 or IPv6 address for IKE Phase 1, version 1 SA.
Specifies the local IPv4 or IPv6 address for IKE Phase 1, version 2 SA.
