Configure RIPng parameters on an interface so you can control RIPng behavior on the interface.
RIPng does not operate on an interface until you enable it globally and on the interface.
Configure a routing interface (either a brouter port or a virtual routing interface).
Assign an IP address to the interface.
Enable RIPng globally and on the interface.
- In the Device Physical View, select a port.
- In the navigation pane, expand the Configuration >EditPort folders.
- Click IPv6.
- Click the RIPng tab.
- In the RipAdminStatus option box, select enable.
- Configure other parameters as required.
- Click Apply.
RIPng Field Descriptions
Use the data in the following table to use the RIPng tab.
Name | Description |
RipAdminStatus |
Enable or disable RIPng on an interface. |
DefaultInfoState |
Enable or disable default information at the interface level. The default is disable. |
Cost |
Specifies the RIPng metric cost. The default is 1. |
Poison |
Enable or disable poison reverse on an RIPng interface. The default is disable. |
RipOperStatus |
Shows the RIPng operational state on an interface. |
