Displays the RIP redistribution configuration information.
View the RIP redistribution configuration information:
Switch(config-ospf)#show ip rip redistribute ================================================================================ RIP Redistribute List - GlobalRouter ================================================================================ SRC-VRF SRC MET ENABLE RPOLICY -------------------------------------------------------------------------------- GlobalRouter ISIS 0 FALSE
Variable definitions
The following table defines parameters for the show ip rip redistribute command or the show ipv6 rip redistribute command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
