There are no authenticated EAP or NEAP clients on a port.
The port is removed from the initial VLANs and moved to Guest VLAN ID.
The default port VLAN ID changes to Guest VLAN ID.
All MACs seen on the port have Guest VLAN access.
Port is removed from the Guest VLAN ID.
If no RADIUS assigned VLAN is present, then the VLAN membership and the default port VLAN ID is restored to default settings.
If the RADIUS assigned VLAN is present, then the VLAN membership and the default port VLAN ID is changed according to its value.
Guest VLAN loses its purpose because all MACs are allowed automatically without authentication
