Configuring the SLPP by VLAN
Activate SLPP on a VLAN to enable forwarding of the SLPP packet over the VLAN. This configuration controls the boundary of SLPP-PDU transmission.
Enable SLPP globally before you configure it on a VLAN.
- Click SLPP.
- Click the VLANS tab.
- Click Insert.
- Click the VlanId ellipses (...).
- Select the desired VLAN ID.
- Click Ok.
- Select SlppEnable.
- Click Insert.
VLANS Field Descriptions
Use the data in the following table to use the VLANS tab.
Name |
Description |
VlanId |
SlppEnable |
Activates SLPP on the selected VLAN. The SLPP packet transmission and reception process is active only if you enable the SLPP operation. If you disable the SLPP operation, the following occurs:
The default is enabled. |
