Use the port lock feature to administratively lock a port or ports to prevent other users from changing port parameters or modifying port action. You cannot modify locked ports until you first unlock the port.
- Click General.
- Click the Port Lock tab.
- To enable port lock, select the Enable check box.
- Click Apply.
Port Lock field descriptions
Use the data in the following table to use the Port Lock tab.
Name |
Description |
Enable |
Activates the port lock feature. Clear this check box to unlock ports. The default is disabled. |
LockedPorts |
Lists the locked ports. Click the ellipsis (...) button to select the ports you want to lock or unlock. |
