View the trap log to see which activity occurred.
  1. In the navigation pane, expand the Configuration > Serviceability > RMON folders.
  2. Click Alarms.
  3. Click the Log tab.
Log Field Descriptions
Use the data in the following table to use the Log tab.
Name
Description
EventIndex
Specifies an index that uniquely identifies an entry in the event table. Each entry defines one event that is generated under appropriate conditions.
Index
Specifies an index that uniquely identifies an entry in the log table generated by the same event entries.
Time
Specifies the creation time for this log entry.
Description
Specifies an implementation dependent description of the event that activated this log entry.
