Enable SPB-PIM Gateway on a brouter port.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Enable SPB-PIM Gateway on a brouter port:
    ip spb-pim-gw enable
    SPB-PIM Gateway cannot be enabled under the following circumstances:
    • If the IP interface is not configured using the brouter command
    • If the IP interface does not exist on the brouter port
    • If the spbm_config_mode boot flag is set to false
    • If ip igmp snooping is enabled
    • If the spb-multicast is enabled on the brouter port
    • If the brouter port is part of an SMLT or vIST Vlan
    • If the brouter port has an i-sid configured
