Configure LACP parameters globally. After you configure the LACP system priority globally, it applies to all LACP-enabled aggregators and ports. After you enable the LACP on an aggregator or a port, it uses the global system priority value.
A change to the global parameter configuration takes effect after you restart the LACP globally or on each port.
![Important](images/important.png)
Important
Changes made at the global level override and reset all port level settings.
Switch:1(config)#lacp fast-periodic-time 2000 Switch:1(config)#lacp enable
The following table defines parameters for the lacp command.
Variable |
Value |
aggr-wait-time <200–2000> |
Configures the aggregation wait time (in milliseconds) globally. The default value is 2000. |
enable |
Enables LACP globally. The default value is disabled. |
fast-periodic-time <200–20000> |
Configures the fast periodic time (in milliseconds) globally. The default value is 1000. |
slow-periodic-time <10000–30000> |
Configures the slow periodic time globally. The default value is 30000. |
smlt-sys-id <0x00:0x00:0x00:0x00:0x00:0x00> |
Configures the LACP system ID globally. Enter a MAC address in the following format: 0x00:0x00:0x00:0x00:0x00:0x00. |
system-priority <0-65535> |
Configures the LACP system priority globally. The default value is 32768. |
timeout-scale <2-10> |
Configures the timeout scale globally. The default value is 3. |
