View all of the ACE IP entries associated with an ACL.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Click Advanced Filters (ACE/ACLs).
  3. Click the ACL tab.
  4. Select the appropriate ACL.
  5. Click IP.
IP field descriptions
Use the data in the following table to use the IP tab.
Name
Description
AclId
Shows the ACL IP ID.
AceId
Shows the ACE ID.
SrcAddrOper
Shows the operators for the ACE IP source address.
SrcAddrIpAddr
Shows the IP source address to match from the IP header.
SrcAddrOperMaskRange
Shows the IP mask value if SrcAddrOper is set to mask, or the highest IP address if SrcAddrOper is set to range.
DstAddrOper
Shows the operators for the ACE IP destination address.
DstAddrIpAddr
Shows the IP destination address to match from the IP header.
DstAddrOperMaskRange
Shows the IP mask value if DstAddrIpAddr is set to mask, or the highest IP address if DstAddrIpAddr is set to range.
DscpList
Shows how the 6-bit DSCP parameter from the TOS byte in the IPv4 header encodes PHB information following RFC 2474.
DscpOper
Shows the operators for the ACE IP DSCP.
DscpOperMask
Shows the mask value in hexadecimal format when the mask option is selected in DscpOper.
ProtoList
Shows the IP protocol type from the IP header to match. The range is 0–255.
ProtoOper
Shows the operators for the ACE IP protocols.
Shows the IP options to match from the IP header.
OptionsOper
Shows the logical operator. Any is the only option.
Fragmentation
Shows the IP fragmentation bits to match from the IP header.
FragOper
Shows the operator for IP fragmentation.
