Perform this procedure to navigate in EDM.
  1. In the navigation pane, expand the Configuration folder.
  2. Click a subfolder to expand the subfolder and see the list of menu options, for example, the VLAN folder.
  3. In a folder or subfolder menu, click an option to open the related tabs.
