Use this procedure to configure the timeout value in the GRT. The timeout value ages out the sender when there are no multicast streams coming from the sender for a specified period of time. The default timeout value is 210 seconds.
You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
You must create the C-VLANs and add slots/ports.
You must enable IP Multicast over Fabric Connect globally.
