Use this procedure to view FA interface configuration.
  1. To enter User EXEC mode, log on to the switch.
  2. View all FA interfaces (ports and MLTs):
    show fa interface
  3. To view FA interface configuration on ports, use one of the following commands:
    • View FA configuration on all ports:
      show fa interface port
    • View FA configuration on a specific port, enter:
      show fa interface port [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
  4. To view FA interface configuration on MLTs, use one of the following commands:
    • View FA configuration on all MLTs:
      show fa interface mlt
    • View FA configuration on a specific MLT:
      show fa interface mlt [<1-512>]
The following example displays sample outputs for the show fa interface command.
Switch:1>show fa interface
                            Fabric Attach Interfaces
INTERFACE    SERVER   MGMT     MGMT     MSG AUTH MSG AUTH    ORIGIN
             STATUS   ISID     CVID     STATUS   KEY
Port2/10     enabled  0        0        enabled  ****
Port4/6      enabled  0        0        enabled  ****
Port4/11     enabled  0        0        enabled  ****
Mlt2         enabled  0        0        enabled  ****
 4 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the port 2/10.
Switch:1>show fa interface port 2/10
 1 out of 4 Total Num of fabric attach interfaces displayed
The following is a sample output for the show fa interface command for the MLT 2.
Switch:1>show fa interface mlt 2
Variable definitions
The following table defines parameters for the show fa interface port command.
Variable
Value
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
The following table defines parameters for the show fa interface mlt command.
Variable
Value
<1–512>
The valid range for MLT ID.
