View a summary of BGP peering over IPv6 transport.
  1. To enter User EXEC mode, log on to the switch.
  2. View BGPv6 summary:
    show bgp ipv6 summary [vrf <WORD 1-16>] [vrfids <0-255>]
The following example shows partial output for the show bgp ipv6 summary command.
Switch:1>show bgp ipv6 summary vrf vrf1
                        BGP ipv6 Summary - VRF vrf1
	                             BGP version - 4
	                                local-as - 200
	                              Identifier - 0.0.0.6
	                          Decision state - Idle
	           The total number of routes is   1
BGPv6 NEIGHBOR INFO :
NEIGHBOR                        RMTAS  STATE       HLDTM  KPALV  HLDCFG KPCFG  WGHT CONRTY ADVINT
2001:DB8:0:0:0:0:0:ffff			     50     Established 180    60     180    60     100  120    5
Total bgpv6 neighbors: 1
BGP CONFEDERATION INFO :
confederation identifier 0
confederation peer as
BGPv6 NETWORK INFO :
                         BGPv6 Networks - VRF vrf1
The following table defines parameters for the show bgp ipv6 summary command.
Variable
Value
vrf
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids
Specifies a range of VRFs by ID number (the ID ranges from 0–255).
