Specify the number of challenges that you want the RADIUS SNMP server to send to authenticate a given session.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click RADIUS.
  3. Click the RADIUS SNMP tab.
    The system displays RADIUS SNMP tab.
  4. Select the Enable check box.
  5. In the ReauthenticateTimer field, enter a value to specify the interval between RADIUS SNMP server reauthentications.
    The timer for reauthentication of the RADIUS SNMP server session is enabled.
    Important
    Important
    To end the RADIUS SNMP server session, enter a value for the AbortSessionTimer, and then select Enable.
  6. Select the AcctEnable check box if desired.
  7. Select Apply.
RADIUS SNMP field descriptions
Use the data in the following table to use the RADIUS SNMP tab.
Name
Description
Enable
Enables or disables timer authentication on the server. The default is true.
AbortSessionTImer
Specifies the allowable time, in seconds, before aborting the RADIUS SNMP server session (30 to 65535). The default is 180.
ReAuthenticateTimer
Specifies the time, in seconds, between reauthentications of the RADIUS SNMP server (30 to 65535). The default is 180.
AcctEnable
Enables or disables the RADIUS SNMP session timer.
UserName
Specifies the user name for the RADIUS SNMP accounting.
