Use this procedure to clear the Application Telemetry status counters. You can clear all of the counters or specify just the counters you want to clear by name or ID.
  1. To enter User EXEC mode, log on to the switch.
  2. Clear Application Telemetry counters:
    clear app—telemetry counter [name <WORD<1–32> | id <1–2000>]
  3. Verify that the counters were cleared:
    show app—telemetry counter [name <WORD<1–32> | id <1–2000>]
Clear the counters.
Switch:1>enable
Switch:1#clear app—telemetry counter
Switch:1>show app—telemetry counter
              Application Telemetry Counters
EntryId			Name					Packets		Bytes
1  			ssh						0		    	0
2  			sslclient			  	0				0
All 2 out of 2 Total Num of Application Telemetry counters entries displayed
