Use the following procedure to link an IPsec policy to an interface, and configure a policy direction. By default, the direction is both.
![Note](images/note.png)
IPsec support on the management port applies to VSP 8600 Series only.
You must enable IPsec on the interface first, and then you link the IPsec policy to the interface.
You cannot delete or modify an IPsec policy if the policy links to a port or VLAN interface. If you need to modify the policy, first unlink the policy from the port or VLAN interface.
Link the IPsec policy newpolicy to the IPv6 interface VLAN 100:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 100 Switch:1(config-if)#ipv6 ipsec policy newpolicy dir both
The following table defines parameters for the ip ipsec policy and ipv6 ipsec policy commands.
Variable |
Value |
WORD<1–32> |
Specifies the policy ID. |
dir <both|in|out> |
Specifies the direction you want to protect with IPsec:
The default is both. |
