The Autonomous System (AS) number configured on the global Virtual Routing Forwarding (VRF) instance, called the GlobalRouter (GRT), is inherited by all user-created VRFs by default, however, you can override the AS number for the specific VRF instance using the following procedure.
Disable BGP synchronization.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf vrfred Switch:1(router-vrf)#ip bgp vrf-as 3
The following table defines parameters for the ip bgp vrf-as command.
Variable |
Value |
WORD<0-11> |
Configures the local autonomous system (AS) number for the specific
VRF instance. You cannot change local-as when BGP is set to
enable.
Note:
If you enable as-dot, enter the AS number in octets in the
range of 1.0 to 65535.65535.If as-4-byte is configured to false, the range for AS number is 0–65535 and if as-4-byte is configured to true, the range is 0–4294967295. The AS number in a specific VRF instance inherits the AS number in the GlobalRouter in the following instances:
