Use the following procedure to limit data transmission during the session.
    enable
    configure terminal
  2. Enter the following command:
    ssh rekey data-limit <1–6>
Configure the data limit to 2 GB:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#ssh rekey data-limit 2
The following table defines parameters for the ssh rekey data-limit command.
Variable
Value
<1–6>
Specifies the SSH rekey data limit in GB. The default is 1 GB.
