Use the following procedure to display the configured IKEv2 profiles.
Switch:1#show ike v2-profile test ========================================================================================== IKE2 Profile ========================================================================================== Hash Encrypt Encrypt Exchange Name Algo Algo Key Length Mode ------------------------------------------------------------------------------------------ test sha256 aesCbc 256 main ========================================================================================== IKE2 Profile ========================================================================================== DH Integrity Lifetime Name Group Algorithm seconds ------------------------------------------------------------------------------------------ test modp2048 sha256 180
The following table defines parameters for the show ike v-2profile command.
Variable |
Value |
WORD<1–32> |
Specifies the name of the policy. |
