This procedure shows how to configure Simplified vIST in an SMLT
environment. It includes steps to configure the following:
![Important](images/important.png)
Important
When you enable Simplified vIST with the virtual-ist enable
command, two VLANs are automatically created to support vIST. The VLAN IDs are: 4086
and 4087.
Important
Do not change the system MTU to less than the default value of 1950 bytes. The
system MTU must be 1950 or jumbo because of a header size increase.
Select the Boot Config
tab.
- Clear the EnableSpbmConfigMode field
to disable the boot flag.
The system responds with the following messages:
Warning: Please save the configuration and reboot
the switch for this to take effect.
Warning: Please carefully save your configuration
file before rebooting the switch. Saving configuration file when spbm-config-mode
is changed to disable, removes SPBM configurations from the configuration
file.
Select Apply.
- Save the configuration, and then reboot the switch.
Important
A change to the EnableSpbmConfigMode boot flag requires a reboot for
the change to take effect.
- Configure the SMLT MLT:
- Expand
the folders.
Select MLT/LACP.
Select the MultiLink/LACP
Trunks tab.
Select Insert.
- In the Id box, type the ID number of the MLT.
- In the PortType section, select access or trunk.
- In the Name box, type a name
for the MLT, or accept the default.
In the PortMembers box, select the (...)
button.
- In the Port Editor: PortMembers dialog box, select the desired
ports.
Select Ok.
In the VlanIdList box, select the (...)
button.
In the VlanIdList dialog box, select the desired VLANs.
Select Ok.
- In the MltType section, select
splitMLT
Select Insert.
The switch adds the SMLT MLT to the MultiLink/LACP Trunks tab in the
MLT_LACP box.
- Configure
the vIST MLT:
- Repeat steps 6.a to 6.o to configure the MLT.
Select
virtualIstMLT to enable Simplified vIST.
Select Insert.
- Create
the vIST VLAN:
- Expand the folders.
In the Basic
tab, Select Insert.
- In the Id box, enter an unused
VLAN ID, or use the ID provided.
In the MstpInstance box, Select the down arrow, and then
choose an MSTI instance from the list.
- In the Type box, select byPort.
In the PortMembers box, Select the (...)
button.
- In the Port Editor: PortMembers dialog box, select the desired ports.
Select OK.
Select Insert.
- Select the vIST VLAN from the list of VLANs, and then
click IP.
Select Insert.
- Configure the IP address for the vIST VLAN.
- Repeat step 8 to create an SMLT VLAN and assign the
SMLT MLT ID to it. Do not use the vIST MLT ID.
