Fabric IPsec Gateway Virtual Machine (VM) provides a File
Transfer Protocol (FTP) CLI to copy the configuration files to the VM.
Perform this procedure to configure an FTP connection to a specific IP Address.
Configuring FTP connection to 192.0.2.50:
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> ftp 192.0.2.50
The following table defines the variable for ftp command.
Variable | Value |
{A.B.C.D} | Specifies the IP Address to establish the FTP connection with. |
